Power UNLOCK works.. Power LOCK doesnt???
Hey guys got a 00 camaro and have had this problem for a long time but just now have time to try andfix it.. whats happening is the keyless and door panel switches for UNLOCK works but neither the keyless entry or door panel switches for lock work it just gives 3 beeps and doesnt do anything.. is there a solenoid gone bad or an electrical problem? it seems like it picks up the signal but doesnt lock it..
thanks
Dustin
thanks
Dustin
nah its not the lockout prevention.. ill pull the door panel and look at the switch itself and hopefully thats it and not the actuator... let ya kno
What gives 3 beeps? The horn?
When I had this issue, mine would act like it locked. It would arm the alarm and everything but not always actually lock the doors. Ended up being one of the lock relays in the BCM. Wasn't sure which relay it was exactly, so I bought a cheap used BCM for 10 bucks from a member here and put its relays in mine. Problem has been fixed ever since.
