HELP! HU Related.
HELP! HU Related.
Im in the process of wiring my subs up, and I know what im doing here, but im in a trouble here, Im using the stock HU for now till I get enough money to buy an aftermarket one, SO anyways, I bought the Line Out Converter with RCA jacks and what not, so the problem is that how do you wire them exactly to the stock wires? like is there a diagram in which it tells you which colored wire are named?
Any help would be appreciated. thanks
Okay well to be more specific, my LOC has wires that need to be connected to:
Right channel positive input
Right channel negative input
Audio ground
Left channel negative input
Left channel positive input
So if you can tell me using the Monsoon FAQ Head Unit connections which wire goes in which that would be 100x easier to me
Audio ground
Audio ground
Audio ground
