99 Camaro Turn Signal Assembly
Old 09-24-2010, 02:44 PM
SSG
SSG's Avatar
Default 99 Camaro Turn Signal Assembly
Does anyone have the socket part number? My turn signal bulbs are constantly going out so I figure it must be the socket. Any help would be appreciated.
Old 09-24-2010, 03:40 PM
djfury05's Avatar
go to Autozone and get part #85881
Old 09-24-2010, 04:03 PM
SSG
SSG's Avatar
Thanks
Old 09-25-2010, 08:57 AM
Save the manuals!
wssix99's Avatar
All the bulbs? Do you have water in the lenses? Have you had any bulbs explode?
Old 09-25-2010, 11:05 PM
SSG
SSG's Avatar
Don't think I have water in the lenses but the bulbs have exploded.
Old 09-25-2010, 11:19 PM
Save the manuals!
wssix99's Avatar
Then you probably have cracked lenses, which is letting water in. Water touching the hot bulb will explode it or cause it to burn out.
If you press on the lens hard with your finger, that will probably expose the cracks. Replacements are reasonably priced. In the meantime, you can put a piece of lens repair tape over the face of the lens to keep water out. You can also drill a weep hole in the bottom of the lens to keep water from pooling in there.
Quick Reply: 99 Camaro Turn Signal Assembly
