Amp Power Wire Fuse?
Old 10-31-2010, 09:39 AM
cyberkill's Avatar
Default Amp Power Wire Fuse?
I know I'm supposed to put a fuse on the power wire that goes from the battery to the amp, but is there a rating on what kind of fuse? 10A, 30A, etc? I'm using an Alpine PDX-5 600W RMS Amp, if it makes any difference.
Old 10-31-2010, 02:28 PM
cyberkill's Avatar
Also, on the amp itself there are two 30a fuses...so 30 amp fuse on power line?
Old 10-31-2010, 05:17 PM
blackram_air's Avatar
you want to get an amp wiring kit. It will come with the fuse and fuse holder, most fuses for the amp wire are 150 amp or more. If you put a 30 amp fuse on that line with the amp having 2 30 amp fuses you will blow the fuse from the battery everytime the amp turns on and draws full current. The amp is drawing 60 amps at full power since it has 2 30 amp fuses.
Old 11-01-2010, 01:38 AM
cyberkill's Avatar
After doing some research, it sounds like Amps = Watts/Volts. So in this situation 600W RMS/12V = 50A
If amp kits come with 150A fuses, wouldn't that potentially allow too high of a current to blow the amp? I unfortunately don't know, and it's not really mentioned, what the peak wattage of the Alpine PDX-5 is.
Anyone else with a PDX-5 here?
Old 11-01-2010, 08:52 AM
Ungrounded Moderator
WhiteBird00's Avatar
You don't install fuses to protect the accessory (amplifier or whatever). You install a fuse to protect the car from fire caused by overheated wire due to excess current flow. So what the amplifier can handle has very little to do with your selection of fuse other than giving you an idea of how much current it could draw. Electrical circuits don't push current - they provide current based on the demand of the attached device. In other words, the amplifier draws the current it needs. You never have to worry about too much current going to the amplifier unless it's already shorted out (and then you worry about the connecting wire not the amplifier).
For example, suppose you install a 1200 watt amplifier. This amplifier is capable of drawing 100 amps in a 12-volt system. Now, if you used 10-gauge wire, installing a 100-amp fuse could allow your car to burn to the ground because 10-gauge wire is designed for 60-amp maximum current flow and you'd be allowing almost twice that (causing the wire to overheat and potentially start a fire).
The object is to choose a fuse that is small enough to blow before the connecting wire overheats but large enough to sustain the current necessary for whatever device is connected. Don't put in a 150-amp fuse unless you are using 0-gauge wire. In the case of your 600W amplifier, it could draw 50-amps so you'll want a 50-amp fuse so that it doesn't blow when you crank up the volume. But you'll also want to make sure you use 8-gauge wire to be sure that the connecting wire isn't going to overheat before the fuse would blow.
Old 11-01-2010, 10:40 AM
cyberkill's Avatar
Thanks WhiteBird!
By the way, before I saw your post, I was doing some heavy Googling, and found this forum post that was really helpful to understand the fuse:
http://www.the12volt.com/installbay/...ID~122533~PN~1
Here's the post (in case link dies):
There are three ways to determine proper fuse size that are generally acceptable:
1. Look at the chart in the bottom right hand corner of this page for your wire size and use the fuse/breaker listed: http://www.the12volt.com/info/recwirsz.asp
2. Add up all the fuses in the equipment you are adding and use a fuse equal to that number AS LONG AS THE FUSE IS NOT GREATER THEN THE NUMBER LISTED IN THE ABOVE LINK FOR YOUR WIRE SIZE.
3. Actually calculate the expected load and use that size fuse/breaker.
So whats the difference in the different methods? The #1 method is the easiest and requires the least work, but may lead to damage to your vehicle when you start getting in to bigger power wires. For anything 8awg or smaller it is probably fine. For anything bigger then that I would use a more appropriately sized fuse.
The second method is pretty straight forward. If you have 3 amps and one has an 80A fuse, one has a 30A fuse and one has a 25A fuse you know that the max current load can never be greater then 80+30+25=135A so you wouldn't need a fuse/breaker bigger then that. This will get you much closer to the actual load required on the wire.
The third method is the most difficult, but the "best" way. It may require some trial and error and you may blow a few fuses in the process. The theory behind it is to try to calculate the expected current on the wire and use the appropriate fuse. Say we are usin the same three amps from above. One is being used as a sub amp (the one with the 80A fuse) and the other two are for mids and highs. You can assume that the sub amp will be bridged and nearly maxed out so assume it actually needs an 80A fuse. Neither of the other two amps will be bridged and they'll both be playing at 4 ohms stereo. Assuming they are both rated for 2ohm bridged you could easily cut the fuses in half and be ok. That would give you 107.5A expected load and you could use a 110A fuse.
So, why does all this matter you may be asking? The fuse/breaker is a safety device intended to offer protection. It provides protection in two ways - from trying to pull too much current through a wire and direct shorts to ground. If you try to pull more current through a wire then it can safely carry the wire WILL heat up and it will eventually start melting and possibly catch on fire. That is why the chart in the link is so important. NEVER use a fuse larger then what is listed in the chart (or larger then the wire manufacture recommends if that number is available). Direct shorts, though, also have to be considered, and this is why using the largest "safe" fuse isn't always the best idea. Fuses are rated to blow based on percentage of load. A 350A fuse may hold 650A for 10 seconds or more before blowing! (http://www.cooperbussmann.com/pdf/08...62dd6ea9a7.pdf) and will allow ~1200A to pass for 1 second before opening up! This has the potential to damage your battery, your alternator, or any electronic device in your vehicle if you were to experience a direct short.
Sorry for the book but this is probably the most critical part of planning a system out!
___________________________________________
Kevin Pierson
Quick Reply: Amp Power Wire Fuse?
