Hatch speaker wiring
Old 01-11-2011, 03:29 PM
APG12's Avatar
Default Hatch speaker wiring
I'm installing the kee audio basic speaker package in my 99 TA with the monsoon system. When swapping in the JVC 2-way speakers in the hatch panels, do I just use the 2 main wires running to the monsoon woofer and not use the separate monsoon tweeter wires, or do they have to be wired to the 2-way speakers also? Obviously, I'm not using the stock monsoon tweeter with the JVC speakers.
Old 01-11-2011, 07:06 PM
APG12's Avatar
This is what I'm referring to.
No longer using the separate tweeter, but do I need to hook up the two tweeter wires (blue connector) to the new 2-way speaker?
Old 01-12-2011, 07:15 AM
Ungrounded Moderator
WhiteBird00's Avatar
No, just connect the pair of wires that was connected to the 4" mid. It receives full-range signal from the Monsoon amp. Cap off the tweeter wires to prevent any shorts.
Old 01-12-2011, 10:33 AM
APG12's Avatar
Excellent that's all I needed, thanks!
Old 05-25-2013, 08:33 PM
No Juice's Avatar
I know this bringin it back from the dead
but can I leave the stock tweeter in place and hooked up as well as add a new CDT 4" 2way to the mid location?
Will it just give me a little more highs from the rear hatch area or will it not sound good?
Old 05-26-2013, 07:13 AM
FSUNole17's Avatar
Will not sound good. Highs in the rear = no no. All you want is mids and lows, if anything, behind you. Best to leave it unhooked
Old 05-27-2013, 04:25 PM
Neenjah's Avatar
+1 sir
Quick Reply: Hatch speaker wiring
