Weird electrical problem. Stereo and windows, no power.
I'll be driving in my 00 Z28 and the stereo randomly turns on and off and when this occurs, I lose power to my windows.
All my dash lights appear to be working, even the electric locks.
The cutout is wired into the fuse box and that still works as well. I can't remember which fuse it's wired into though. All i know is that it was unrelated, like the horn or something.
Basically, what could be causing this, is there a certain area where these wires could be tied together like a common ground. Pretty sure the stereo ground is behind the stereo, the only thing I can think of is, that these two power wires could be shorting out somewhere.
Maybe there is a better way to wire to cutout? It's been awhile since I did this, but I swear i unhooked the cutout sometime last summer and the stereo still turned on and off.
Its a common problem with the BCM, theres a solder joint that gets brittle and cracks, theres an easy fix for it, search around for "BCM Fix"
https://ls1tech.com/forums/general-l...blems-fix.html
