Fog light wiring help!!!
ok everybody i have a 2001 camaro i know the fog lights are usually purple and black but i am very confused because the 2 wire in my right fog light (facing the car) is red with of course the black ground and the left side wires where ripped out when i got it .. so i am very lost !!
Ungrounded Moderator
What is the question? It sounds like a previous owner has butchered the fog light wiring for whatever reason and you will have to do some tracing to find the original wires. The wiring runs from the fog light relay in the junction box on the left fender liner (BTW, left and right is always determined from the driver's seat) to the fog lights. If you start there, you should be able to find where the wires have been cut.
Check your options sticker for code T96. If the code is there then your car came with fog lights from the factory.
I suspect it didn't because the wiring should not go directly from the switch to the lights. It should go through the fog light relay under the hood.
