Turn Signal Arm
Old 08-05-2011, 02:02 PM
Stocker94z's Avatar
Default Turn Signal Arm
Hey guys. I have a 99 Camaro and the horn quit working so I took it all apart(steering wheel) and found that the little sleeve that the spring goes inside is broken and needs replaced. Does anyone know what this part is called? I could post pictures later if needed. Thanks.
Old 08-07-2011, 11:45 AM
LS1121's Avatar
is this what you mean?
http://cgi.ebay.com/ebaymotors/1998-...Q5fAccessories
Old 08-07-2011, 01:06 PM
Save the manuals!
wssix99's Avatar
LS1Tech 10 Year
Very common. The spring engages a sleeve that is molded in to the turn signal cam. Its in the last picture in step 16: https://ls1tech.com/forums/general-m...mn-repair.html
Old 08-07-2011, 02:49 PM
Stocker94z's Avatar
Thanks! Much appreciated.
