Push Button Start Question
Recently I've gone about doing the push button start for my 2000 Camaro SS A4. Car was working flawlessly prior to installation. I've .pdf'd the guide I used here: http://www.scribd.com/doc/92995448/C...h-Putton-Start. The only difference is I spliced the yellow starter wire to allow for both key and push button starts.
I completed all the wiring, triple checked it etc. When I go to turn the car over with the key for the first time to test, the engine cranks for a second or two then died. I smelled something kind of burning, inspected everything, checked everything, looked fine. I suspect maybe a fuse?
So I go to start the car over again with the key, again then the engine cranks for a second or two then dies. No burning smell since that first time. I then try to start the car with the push button starter - the engine cranks for a second or two then dies. Same thing.
I'm going to have a look over the wiring (again) and check the fuses again today, but other than that I am kind of befuddled.
Any insight?
And I wired it so that the key still has to be in the ON postion, and I can start it either by turning the key to crank the ignition, or hit the I/O switch to activate the start button.
my car has a starter button installed (not a S2000 one, just a crappy one that the words are wearing off of. i plan to change it out), but my key switch will no longer work. you put the key in, turn it to the run position and then push the start button.
when i was installing a new clutch master i noticed that my yellow wire was cut like the instructions show.
it i reconnect the yellow wire from the push button to the key switch and then just tap into the yellow wire for the push button, will that allow both to function?
And yes i'm sofa king, that would make sense. As I understand it, if you cut the yellow wire, you disable the option to simply start your car with the key. So by reconnecting the original yellow wire back to the key, and then splicing the push button starter in, you should be good to go. That's the way mine is wired.
Did you find out if it was more of a ground issue, then gauge of wire?
And Black_Z28, I did the 14 gauge re-wiring carefully...but my gut feeling is one of the grounds wasn't completely grounded for one reason or another.
