Embarrassing Newbie Question
Old Apr 24, 2012 | 07:48 AM
Whitefish's Avatar
Default Embarrassing Newbie Question
I have an 02 SS with 17k miles that I plan to show this season. Now, I am also a C-grade mechanic (at best) & don't want to break anything. So, here comes my dumb question....how in the hell do you remove the door panels? I have a blown front driver side speaker & need to replace it, but am afraid to break something getting into it. I would also like to replace the speaker myself so I can use the extra cash for more performance parts. Thanks & sorry if this is one of those questions that get asked all the time. I did a search & found nothing actually showing how to get to the speaker. Thanks again.
Old Apr 24, 2012 | 07:57 AM
blackodium's Avatar
In the TA world there are 4 screws...... There is a triangular plaque beside the side view mirror held by one screw. That = 5 screws total. you must remove the lock mechanism (plastic lever). Unplug the wire harnesses from the switches and push them through the door panel. After this lift up on the panel. Be precise yet strong. Best of luck!
Old Apr 24, 2012 | 08:14 AM
Capricio's Avatar
...10 seconds in google later.
http://www.firebirdnation.com/pdf/doorpanel.pdf
Old Apr 24, 2012 | 09:00 AM
Whitefish's Avatar
Originally Posted by Capricio
That is funny. I didn't bother to search google, just here. I told you it was a dumb question.
Old Apr 24, 2012 | 09:20 AM
2002ss335's Avatar
Here is another link that might help.
Camaro door panel removal step by step:
http://shbox.com/page/windowmotor.html
Be careful with the locating pins behind the triangle up by the mirror. They will fall out and get lost.
Todd
Old Apr 24, 2012 | 09:33 AM
Nick V.'s Avatar
Todd
pfft i wish i was that lucky, when i got mine the part they clipped to was too worn to work
O.P- dont worry its actually easy getting them off, popping them back in at the bottom is a PITA though
Old Apr 24, 2012 | 09:42 AM
Whitefish's Avatar
Thanks for the help!! I totally would have broken something, had I not seen those how-to's!
Old Apr 24, 2012 | 03:03 PM
LE35thSS's Avatar
damn right. when i replaced my door speakers putting the panels back on caused me to cuss so much i would've made a sailor blush.
Old Apr 24, 2012 | 05:18 PM
JrodCamaro's Avatar
^ 2nd that. Only I didn't get the fun of new speakers, it was a window regulator
Old May 18, 2012 | 11:25 PM
Whitefish's Avatar
Finally got the speaker & had some time to tear into it...man it really was easy! It took me all of three minutes to get the panel back on. I was super amazed at how easy it went on....I must have just gotten lucky. Thanks again for the write-ups, they really helped!
Old May 19, 2012 | 03:22 AM
Daniel Richards's Avatar
****, the panels easy and I don't even remove the triangle piece at the sideview mirror the bitch is getting the damn little plastic piece to snap back onto the interior door lock rod.
Not to mention those insanely long screws that hold the panel on.
