issue
Old Jun 6, 2012 | 10:07 PM
99Mutt's Avatar
Default issue
im having a issue with my running lights..i keep blowin the fuse for the runnin lights..its blowin 40amp fuses..sometimes i can get the fuse to go in and it not blow and itll work good for about a week..then itll blow..then somtimes i cant even replace the fuse without it blowin the new one right off the bat..i know i have a short somewhere..but could it be a fuse box itself? or can anyone tell me what all accessorys are runnin to that fuse?
Old Jun 7, 2012 | 07:27 AM
WhiteBird00's Avatar
Ungrounded Moderator
A 40 amp fuse? Are you trying to burn your car for the insurance money? Why not just put a piece of 16 gauge wire across the fuse terminals?
The TAIL LPS fuse protects all exterior running lights and the fog lights as well as interior lights through the IP DIMMER fuse. Any portion of those circuits could have a dead short to ground that would blow the fuse including light sockets, headlight switch, panel dimmer switch, or any of the wiring in between. It is not likely the fuse panel because there is no ground in the panel for wires to short to. First, go get yourself a big stack of the proper 20-amp fuses - you're going to blow a lot of them while looking for the short. Unless you recently did some electrical work (which would be the first place to look), I expect you will have to spend some time tracing individual circuits looking for shorts from wires with damaged insulation. Start by unplugging the headlight, fog light and dimmer switches and see if that keeps the fuse from blowing.
Old Jun 7, 2012 | 09:54 AM
99Mutt's Avatar
Im gonna trace all my wires today..aparently someone has already replaced the rear blinker socket
Old Jun 8, 2012 | 07:04 AM
That replaced socket is the first place to look. Owner modifications or repairs are responsible for electrical problems far more often than undisturbed factory wiring.
Old Jun 8, 2012 | 11:46 AM
99Mutt's Avatar
I pulled every bulb out including my switch and still wont let me put a fuse in without fryin it..I checked all plugs..still fryin fuses
Old Sep 28, 2012 | 06:38 PM
cleb's Avatar
i need help fixin this problem too
Old Oct 2, 2012 | 11:34 AM
cleb's Avatar
I found my problem. I pinched one of the wires where the tailights bolt on to the car last time i switched my tailights out. I think it's one of the common things to happen.
