sound deadening trunk area
Can anybody recommend which material works best; Fat Mat, Dynamat or Gorilla shield? Looking for Butyl material. Also best way to cut and fit for 98-02 F Body trunk to fit nicely? it doesn't look like a clean fit-Thanks in Advance
i used roadkill. cheaper than dynamat and same quality. as for a clean fit, its rectangle sheets, but once u get going, u cut it to fit however. and it gets covered so function is better than form.
I should also mention, I used a "fondant" roller to roll the product. It is the perfect tool.
I removed the entire interor (dash excluded) and layed down the second skin. I saved a few squares to use inside my doors when I taken them apart to install the new speakers from kee audio. The whole think took me 2 days to do.
Also look into something like a "luxury liner pro" to use specifically in your doors. They are quite obviously areas that are noisy.
Took me
Took me
