Numbers not lit - Camaro Monsoon HU
I am having trouble with my Camaro Monsoon head unit. For some reason, when I turn my parking lights or headlights on, the numbers and several of the other buttons wont light. Only the bulb nearest the power and volume ***** seem to be lighting, as well as the LCD display. Everything else seems to function just fine, and the buttons do what they are supposed to do when you push them. I checked the Monsoon faq, especially the wiring part, but didn`t see anything that singled out these lights. These HU`s don`t have a daylight sensor do they?
Thanks.
Thanks.
Thanks.
Thanks.
Save the manuals!
Here is the thread you need. You have a number of bulbs out:
This thread instructs on how to replace the small bulbs all over. (Note further down, there are part numbers and instructions for the original incandescent bulbs - instead of LED's) https://ls1tech.com/forums/stereo-el...hen-i-did.html
If you look at post #27, you'll see the p/n for the special bulb that lights your numbers display.
