rear dome light blowing fuses?
Old 10-21-2014, 12:58 AM
Mr Phil's Avatar
Default rear dome light blowing fuses?
So I went to replace rear dome light in the ta, and instantly blows the fuse, switch out the fuse and blows that one right away too. Why would it do this?
And on another note, there's this tick noise like every 15 seconds coming from the glove box area, Wtf is that? Almost sounds like a turn signal click
Car is a 98 trans am
Old 10-22-2014, 11:54 AM
2nd Gen Fl 'bird's Avatar
Bump! This just happened to me as well. Havn't had time to look into yet but, if someone has remedied this, it would be nice to know.
Old 10-23-2014, 12:54 AM
Copy & Paste Moderator
VIP1's Avatar
Sounds like a problem in the BCM. Any other symptoms? Maybe like other lights or windows or radio intermittently not working?
Old 10-23-2014, 09:25 AM
Can't speak for the OP but, no other issues as far as mine goes. The SES light is on but, I think it's from that POS skip shift I installed and doesn't seem to work. I had bought a LED bulb for the rear interior light and as soon as I installed it it blew a fuse. Put in new fuse and popped it again. Left it alone at that point and have not looked at it since. It's a simple wire to and from receptacle. Maybe the LED bulb caused it?
Old 10-23-2014, 09:30 AM
OK. Curiosity was killing me. Went out and reinstalled the factory bulb and all is good. No blown fuse and working properly. POS LED bulb I guess, how ever that works.
Old 10-24-2014, 12:25 AM
VIP1's Avatar
Probably a short in the LED bulb then.
Quick Reply: rear dome light blowing fuses?
