water temp gauge ?
water temp gauge ?
i recently got a digital cyberdyne water temp. gauge. i hooked up the power ground, and sender, and everything was working fine. today on my way home from work, the temp kept rising, and rising. eventually it just read "HI"
I have the sender hooked up to the passenger side of the block, behind the coil packs, i dont see any obvious wiring problems, but im not 100% sure. it isnt impossible that i screwed something up somewhere. any ideas on what is causing this problem is appreciated. thanks
