installing starter button, toggle
Old 07-12-2004, 02:58 PM
WhiteMuscleLT1's Avatar
Default installing starter button, toggle
i want to install a toggle switch with positions for off run and start, to bypass the ignition switch from the bottom of the steering column, ive gone through three of these and they keep fuking up on me. also i want a separate switch for accessory power. does anyone have a wiring schematic for the wires to the ignition switch on the column?
Old 07-13-2004, 01:59 PM
STF Veteran
TA TED's Avatar
Under the drivers dash just foward of the steering column, find a bundle with #10 and #12 wires in it.
Red - Hot 12v supply
Pink - ignition 1 (engine/PCM/fuel pump etc)
Orange - ignition 2 ( HVAC)
Bwn - Accessory (windows/radio)
Yellow or purple - starter
Old 07-13-2004, 03:36 PM
thanks a lot thats what i was lookin for
Old 07-13-2004, 08:04 PM
Ungrounded Moderator
WhiteBird00's Avatar
Don't forget that you will have to bypass the VATS system if you want to start the car without the key.
