NBS silverado...voltage drain
i have heard grounds in these trucks suck anyways, but i am having major voltage drain running only 2 competition 10" subs with a 700 watt amp. just wanted to get some opinions on what to do to help reduce/eliminate this prob. i am already running a red top, but nothing else (i.e. high amp alt., bigger ground wire, batcap, or capacitor).
I would also research the big 3 (running lower gauge wire between the battery and alternator, battery and chassis ground, and alternator/engine to chassis ground. I did that and am getting a constant 15.+ and 14.+ under complet load. This is in a 2002 TA. Make sure you scrape to bare metal for all grounds.
