shift light stays on?
Old 06-15-2005, 06:53 PM
408Maro's Avatar
Default shift light stays on?
ok i have a autometer tach w/shift light the tach works fine but the shift light always stays on,any thoughts?
Old 06-18-2005, 06:48 PM
408Maro's Avatar
any1 got any thoughts?
Old 06-18-2005, 08:35 PM
2MuchRiceMakesMeSick's Avatar
Has it always been like this or did it just start doing it? Have you made any recent changes to your car?
Old 06-18-2005, 11:14 PM
408Maro's Avatar
no its always been like that since i hooked it up. and i havent done no changes to the car since its been in.,its weird
Old 06-19-2005, 01:08 AM
So it has never worked meaning either it is a bad shift light or it was hooked up wrong. I know its an auto meter but what series is it?
Old 06-19-2005, 09:19 AM
408Maro's Avatar
sports-comp monster tach
Old 06-21-2005, 02:36 PM
zfastss's Avatar
Make sure the shiftlight/tach is set up for 4-cylinder mode. Yes 4-cylinder! There's something with our ignition system that sends the tach signal in a form that is usually used in 4-cylinder engines. Do a seach for more accurate info on that if you'd like. Also make sure the hookups are correct. If the tach is working fine, and all that is wrong is the shiftlight staying on all the time, I'd bet that the light is wired to a constant 12v source instead of the tach signal. I'm not familiar with the workings of automerer though, but I assume that there is ground, +12v, and tach signal wires for the light, and perhaps you have the +12v and tach signal wires switched? I have a raptor shiftlight (set to 4-cylinder mode) on my 2002. Here's a good site to check for pictures of the proper wire hookups. The pictures are for a 98, but they also list the proper wires for different years. http://www.raptorperformance.com/chevrolet_camaro.htm
I hope this helps you some
Andrew
Quick Reply: shift light stays on?
