Gauge Lights do not go on when headlights come on
Old 07-29-2005, 01:44 PM
1FASTZ28's Avatar
Default Gauge Lights do not go on when headlights come on
Just recently my lights on my gauge have not been coming on when my headlights are turned on. My fuse for my tail lights was blown causing them to not work and has still not been replaced, but would that cause the guage to not work. I checked the fuse for these as well and that one seems to be fine. Any help would be appreciated. Thanks
Old 07-29-2005, 01:53 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Same thing happened to me, at night when I turned the lights on all the guages and radio lights would not come on. I had to replace the 5amp fuse at the bottom of the fuse box. So you might want to check that one out if you have not.
Old 07-31-2005, 07:31 PM
1FASTZ28's Avatar
Well I checked all my fuses and replaced the blown ones. They are all fine now and still no guage lights or radio lights. My tail lights now work, but idk what is wrong with my guages.
Old 08-02-2005, 04:43 PM
Ungrounded Moderator
WhiteBird00's Avatar
Check that the dimmer switch isn't turned all the way down.
Old 08-06-2005, 08:55 AM
blue01ta's Avatar
Make sure the dimmer switch isn't shorting out too. Could be a bad connection in the circuit.
Old 08-06-2005, 01:47 PM
Danny2tek's Avatar
Yea I would check the dimmer switch.
Old 08-06-2005, 03:24 PM
1FASTZ28's Avatar
Dimmer Switch is all the way up first thing I checked, looks like I will have to make sure there is no short in it. Thanks, any other ideas post them.
