Escort radar detector direct wire
I have the escort smartcord direct wire kit and after searching it looks like I can tap a wire coming off of the ASR or foglight switches. If I do this will the radar come on at ignition or accessory? I would prefer ignition so if its not beeping like crazy when I park near an automatic door. Also, which wire coming off the switch do I use(ie what color) and what gauge is it? Thanks!
Ungrounded Moderator
All power to the fog light switch is headlight controlled and I'm sure you want to be able to use your detector without the headlights being on.
The pink wire at the ASR switch (TCS switch on Firebird) is the power supply and is hot in RUN only. You could also use the yellow wire in the black 10-pin connector in the back of the radio. It is hot in RUN, ACCY and when RAP is active.
SSU's Drunk Typing Whore
I just did the same thing a couple weeks ago with my x50. I used these direction and got everything to work perfectly. The detector goes on when I start the car and goes off when I turn the car off. http://www.ls1howto.com/index.php?article=14.
Dont know much about this stuff obviously
Thanks all, that worked. I used the pink ASR wire and grounded to the radio screw. I had to cut off the tap-in plug that comes on the escort direct wire cord and use a tap-in from radio shack.
