Autometer gauges, Need tech help
Anyone have or know of anyone with write-ups on installing autometer gauges, I am trying to install an oil pressure, water temp, and an air fuel ratio in a 2000 SS, the wiring guides just say to wire into the computer, i'm clueless, any help would be appreciated.
Thanks
Thanks
water temp you need to get an adapter and run it to the plug at the back of your pass side head. F**K autobarn because two of the adapters I used from them broke with less than 1ft/lb pressure, but the first one lasted over a year.. go figure...umm oil pressure there is a plug above the oil filter and I believe you have to run a 90* to get it to fit properly. I dont have one but i remember reading a write up, do a search and you'll find it hopefully with pics
