Not sure how to mount my new HU
Just got my new HU today. I'm pretty new at this, but I did a preliminary wiring and I got it working, if you can believe it. Anyway, the mounting kit I got doesn't really seem to be a mounting kit at all. It looks more like just a faceplate. Links to pictures are below. This is all I have to mount my HU unless I'm really missing something?
(copy and paste)
http://www.geocities.com/jsramair/images/MB001x.jpg
http://www.geocities.com/jsramair/images/MB002x.jpg
Also, I've read in some past posts that some people have to trim a piece off the mounting bracket in the dash to keep the HU from sticking out too far. Is this the piece they were talking about?
http://www.geocities.com/jsramair/images/MB003x.jpg
(copy and paste)
OK, lets see if i can explain this... your cd player should have came with a metal sleve looking thing.. the metal sleve thing sticks inside of that plastic (face plate) you took the pictures of... then the "face plate" bolts to the car with the bolts you took out of the factory player... then your new cdplayer will slide into the "sleve" and should lock in it... thats probably the best i can explain it
edit: when you put the sleve through the "face plate" you took the pictures of... they will be triangle tabs on the sleve that you need to bed up to keep the sleve stuck into the faceplate.. i hope this helps
This pieice you circled red is what you have to break off - so your HU doesn't stick out too far.
Once you break the plastic peice -the red one you circled in the picture- you will still have a metal peice that you will then just bend it down so your new radio doesn't stick out too far. I see you own a WS6 I own a Camaro but the peice is the same on my car.
Thanks for the help. I got it put in today and it looks pretty good. Had a lot of minor problems, which were mostly my fault, but I got them all worked out.
