Corvette System Help
Posted in other forum already oops...
Anway I have a 2001 Z06
I have 2channel Amp with Sub
I have Pioneer Premier 760
What exactly do I need to install everything
So far I've gathered
1. dash kit.not sure which
2. antenna adapter
3. Periphel SVHGM4 wiring harness or w/e
4. Periphiel SVEN2
anyone have any suggestions or had expeirnce iwth this...problem is i ahve bose speakers and there really stupid
2. antenna adapter
4. Periphiel SVEN2
Well, to install that sub and amp you will also need:
1) an appropriate box for the sub
2) Power wire +12v (from battery to amp)
3) Ground wire -12v (from body of car to amp)
4) Amp turn on wire (from head unit to amp)
5) Speaker wire (from amp to sub)
6) RCA cables (from your head unit to the amp) also (I am assuming by "Pioneer Premere 760" you mean model DEH-P760MP)
The size of the power and ground cables are dependant on the amount of power your amp needs and the distance from the battery to the amp. he amp turn on wire is just a small wire which turns on the amp. The rest are pretty obvious. You can buy all the required wiring either in a "kit" form or seperately. Also, it is possible to spend more money on wire than on your equiptment if you let a sales drone feed you too much BS in a stereo shop. You can get quality wire without spending an arm and a leg if you shop around.
To interface the aftermarker radio with your bose system you will need the SVEN4 not the SVEN2, If you have OnStar and want to retain it I think you have to use something like the "Soundgate GMCRV1 Radio Replacement Interface" or something like that, not 100% on that one though.
yeah i have the ph760, as far as the sub and amp go I already have them hooked up had to use a converter interface for the amp but are you sure i need the sven4? cause everyoen i've talked to says i need the 2?
