2001 Trans Am Pin Out
Old 05-15-2007, 02:10 PM
Restricted User
Zero4488's Avatar
Default 2001 Trans Am Pin Out
Does anyone have the ECU Pin Out for a 2001 Trans Am?
Old 05-17-2007, 01:25 PM
Ungrounded Moderator
WhiteBird00's Avatar
Here you go...
PCM Blue Connector
1 - BLACK - PCM Ground
2 - LIGHT GREEN - Crankshaft Position Sensor B+ Supply
3 - PINK/BLACK - Injector 3 Control
4 - LIGHT GREEN/BLACK - Injector 2 Control
5 - Not Used
6 - Not Used
7 - Not Used
8 - GRAY - TP Sensor 5V Reference
9 - Not Used
10 - Not Used
11 - LIGHT BLUE - Knock Sensor Signal Rear
12 - DARK BLUE/WHITE - Crankshaft Position Sensor Signal
13 - Not Used
14 - Not Used
15 - Not Used
16 - Not Used
17 - DARK BLUE - Transmission Range Signal B
18 - RED - Transmission Range Signal C
19 - PINK - Ignition Positive Voltage
20 - ORANGE - Battery Positive Voltage
21 - YELLOW/BLACK - Crankshaft Position Sensor Reference Low
22 - Not Used
23 - GRAY - Fuel Tank Pressure Sensor/Fuel Tank Sender Ground
24 - Not Used
25 - TAN - HO2S Signal Low Bank 2 Sensor 2
26 - TAN - HO2S Signal Low Bank 2 Sensor 1
27 - Not Used
28 - TAN/WHITE - HO2S Signal Low Bank 1 Sensor 2
29 - TAN/WHITE - HO2S Signal Low Bank 1 Sensor 1
30 - Not Used
31 - Not Used
32 - GRAY - Clutch Pedal Position Switch Signal
33 - PURPLE - TCC Brake Switch
34 - ORANGE/BLACK - PNP Switch Signal
35 - Not Used
36 - BLACK - Injector 1 Control
37 - YELLOW/BLACK - Injector 6 Control
38 - Not Used
39 - Not Used
40 - BLACK - PCM Ground
41 - BLACK - EGR Pintle Position Sensor Ground
42 - DARK GREEN - Engine Cooling Fan Relay 1 Control
43 - RED/BLACK - Injector 7 Control
44 - LIGHT BLUE/BLACK - Injector 4 Control
45 - GRAY - A/C Refrigerant Pressure Sensor 5V Reference
46 - GRAY - Fuel Tank Pressure Sensor 5V Reference
47 - GRAY - EGR Pintle Position Sensor 5V Reference
48 - GRAY - MAP Sensor 5V Reference
49 - Not Used
50 - Not Used
51 - DARK BLUE - Knock Sensor Signal Front
52 - Not Used
53 - BLACK - Transmission Temperature Sensor Ground
54 - ORANGE/BLACK - MAP Sensor Ground
55 - BROWN - EGR Pintle Position Sensor Signal
56 - Not Used
57 - ORANGE - Battery Positive Voltage
58 - DARK GREEN - Serial Data
59 - Not Used
60 - BLACK - TP Sensor Ground
61 - PINK/BLACK - Camshaft Position Sensor Reference Low
62 - Not Used
63 - Not Used
64 - Not Used
65 - PURPLE - HO2S Signal High Bank 2 Sensor 2
66 - PURPLE - HO2S Signal High Bank 2 Sensor 1
67 - Not Used
68 - PURPLE/WHITE - HO2S Signal High Bank 1 Sensor 2
69 - PURPLE/WHITE - HO2S Signal High Bank 1 Sensor 1
70 - BROWN - Low Oil Level Switch
71 - Not Used
72 - Not Used
73 - BROWN/WHITE - Camshaft Position (CMP) Sensor Signal
74 - YELLOW - Engine Coolant Temperature (ECT) Sensor Signal
75 - Not Used
76 - BLACK/WHITE - Injector 5 Control
77 - DARK BLUE/WHITE - Injector 8 Control
78 - Not Used
79 - GRAY or WHITE - Skip Shift Solenoid Control (M/T) or 3-2 Shift Solenoid Control (A/T)
80 - BLACK - Engine Coolant Temperature (ECT) Sensor Ground
PCM Red Connector
2 - BROWN - TCC Control Solenoid
3 - Not Used
4 - PURPLE - AIR Solenoid Relay Control
5 - Not Used
6 - RED/BLACK - Transmission Fluid Pressure Control Solenoid High
7 - RED - EGR Control
8 - LIGHT BLUE/WHITE - Transmission Fluid Pressure Control Solenoid Low
9 - DARK GREEN/WHITE - Fuel Pump Relay Control
10 - WHITE - Engine Speed (Tach) Output Signal
11 - Not Used
12 - Not Used
13 - WHITE - Cruise Control Enable Signal
14 - RED/BLACK - A/C Refrigerant Pressure Sensor Signal
15 - RED - Alternator L Terminal
16 - Not Used
17 - DARK GREEN/WHITE - A/C Request Signal
18 - DARK GREEN - A/C Status Signal
19 - Not Used
20 - LIGHT GREEN/BLACK - Vehicle Speed Sensor (VSS) Reference Low
21 - PURPLE/WHITE - Vehicle Speed Sensor (VSS) Signal
22 - Not Used
23 - Not Used
24 - DARK BLUE - TP Sensor Signal
25 - TAN - IAT Sensor Signal
26 - PURPLE - Ignition Control 1
27 - RED - Ignition Control 7
28 - LIGHT BLUE/WHITE - Ignition Control 6
29 - DARK GREEN/WHITE - Ignition Control 4
30 - DARK BLUE - VTD Fuel Enable Signal
31 - YELLOW - MAF Sensor Signal
32 - LIGHT GREEN - MAP Sensor Signal
33 - DARK BLUE - Engine Cooling Fan Relay 2 and 3 Control
34 - DARK GREEN/WHITE - EVAP Canister Purge Valve Control
35 - Not Used
36 - BROWN - AIR Pump Relay Control
37 - DARK GREEN - Cruise Control Inhibit
38 - Not Used
39 - RED - Camshaft Position Sensor B+ Supply
41 - GRAY - EGR Position Sensor Ground
42 - TAN/BLACK - TCC Enable Circuit
43 - DARK GREEN/WHITE - A/C Clutch Relay Control
44 - LIGHT GREEN - Reverse Inhibit Solenoid Control
45 - WHITE - EVAP Canister Vent Valve Control
46 - BROWN/WHITE - Malfunction Indicator Lamp (MIL) Control
47 - YELLOW/BLACK - Transmission Shift Solenoid B
48 - LIGHT GREEN - Transmission Shift Solenoid A
49 - Not Used
50 - DARK GREEN/WHITE - Vehicle Speed Output Circuit
51 - YELLOW/BLACK - Transmission Temperature Sensor Signal
52 - Not Used
53 - GRAY/BLACK - Spark Retard Signal
54 - PURPLE - Fuel Level Sensor Signal
55 - Not Used
56 - Not Used
57 - PURPLE - IAT Sensor Ground
58 - Not Used
59 - Not Used
60 - BROWN - Ignition Control Reference Low Bank 1
61 - BROWN/WHITE - Ignition Control Reference Low Bank 2
62 - Not Used
63 - PINK - Transmission Range Signal A
64 - DARK GREEN - Fuel Tank Pressure Sensor Signal
65 - Not Used
66 - PURPLE/WHITE - Ignition Control 8
67 - RED/WHITE - Ignition Control 2
68 - DARK GREEN - Ignition Control 5
69 - LIGHT BLUE - Ignition Control 3
70 - Not Used
71 - Not Used
72 - Not Used
73 - Not Used
74 - Not Used
75 - Not Used
76 - LIGHT GREEN/WHITE - IAC Coil B High
77 - LIGHT GREEN/BLACK - IAC Coil B Low
78 - LIGHT BLUE/BLACK - IAC Coil A Low
79 - LIGHT BLUE/WHITE - IAC Coil A High
80 - Not Used
Old 05-17-2007, 02:04 PM
Restricted User
Zero4488's Avatar
Thanks Alot...
Quick Reply: 2001 Trans Am Pin Out
