Gm Aux9
Gm Aux9
Will this work with this head unit (it has the 12 disc changer in trunk)
or this one?
I would prefer the CD player version, I understand I will be losing the CD changer abilities and that is fine. Like I said I just wanted to make sure that this:
http://www.logjamelectronics.com/piegm9aux.html
worked with one of the above decks and preferably the CD player
TIA
or this one?
TIA
yes sir it will if it has the connection for the cd changer harness on the back. i did the same thing with my old blazer had a tape in the dash and a cd in the console so i had two cds players needless to say.
Ungrounded Moderator
As explained in the Monsoon FAQ sticky, a head unit has to be able to control an external CD changer in order for the auxiliary adapter to work. All cassette head units were capable of controlling the changer but only CD head units that were from late 99 or later had that ability.
In your case, since you already know that the CD head unit has a changer, the adpater will work with either one of those head units. In fact, if the CD head unit is from an 01 or 02 model then you can add the auxiliary adapter and still keep the CD changer (01 and 02 models had the ability to have more than one external device connected).
