HELP! Window Wont roll up!
Old 06-21-2007, 01:03 AM
Silver UltraZ's Avatar
Default HELP! Window Wont roll up!
Alright heres the story First Let me say, Im a moron...
I was taking off my drivers side door panel and I couldnt get the window switch unplugged from wire harness, So I proceeded to get get a flat head to pry it off and help the process out and i forgot that i had my ignition to run, I slipped and I think grounded the switch or the harness, saw a spark everything shut off but came right on, The fuse is still good, The Drivers side window will roll up, But the passenger will not, It wont even go up with the passenger side window swithch, Whad I do? HELP PLEASE!!
Is it the Swith? Is the Motor? Is it the harness? Im a retrard!
Old 06-21-2007, 01:41 PM
2001NBMZ28's Avatar
Easiest thing to try is plug in a switch from a friends car. Had something similar when my passenger window died - neither switch would work. After replacing the window motor the passenger switch would work, but the drivers side switch for it wouldn't. Swapped in one temporarily and it worked - so bought a new drivers side switch. If you need one the PN is 10402842.
