replacing door speaker
can someone run me thru replacing the door speaker. my passenger side door speaker is blown and i need to replace it. does anyone have a part number and install instructions? thanks a bunch
Its not that hard.
Remove the switch bezel, should just pull up. One clip holds it down.
Unplug switches, set aside.
remove 1 screw that holds the cover over the door handle. Watch out for the lock indicator, it just snaps in.
There are 3 big screws that hold the panel to the door, 2 are in the handle part, where you pull it to close it. The other one is under the other part of the handle.
Remove the screw that holds the cover behind the rearview mirror.
Pull door up slowly. Set aside.
You will see the speaker in the door. There are 3-4 screws holding it in the plastic bracket.
