Rear seat side speakers...which ones to get?
I have a 500W Monsoon system on my T/A
I'm talking about the speakers (one on each side) next to the rear seat tubs
What's the dimension?
What's the best pair (that will accomodate the high power Monsoon) to get and their approximate price?
Thanks in advance.
Thanks in advance.
I believe those at 6.5" sail panel "subs", dual voice coil (4ohm). As far as replacing them, are you going aftermarket? Cause if so you might consider putting in a new amp to power them. Not only because of the power issues, but simply because Monsoon is pretty picky about what works best.
If you have questions about how the Monsoon system works and just general info, check out this thread:
https://ls1tech.com/forums/wiring-stereo-electronics/612644-monsoon-faq.html
