can someone do a wiring diagram for me?
i have a cheetah scs shifter with the button on the handle. what i am looking to to is make this button work 2 functions. trans brake and line lock. so i will need a 3 way switch up turns on one, middle is off and down is for another can someone help me out with this?
Thanks Rich
Thanks Rich
Hot wire to middle
up turns on bottem fuction (wire to trans brake hot wire)
down turns on top function (wire to line lock hot wire)
This can be done with the ground also just use ground where I have hot.
use a three pole switch. run a ground to the middle of it. run the ground to the line lock of of 1 side and the ground of the transbrake to the other. This way when the toggle switch is up you only have a ground to the function you want.
You would wire the shifter switch as normal but the hot would go to two solonoids instead of 1. This help any.
When you mash the switch it will power both circuits. If you run the grounds to the switch (3 pole) only that circuit will function as it is the only one w/ a ground.
You can do it the same way with the hot wire. Hook up grounds as normal. Send the power from the switch (shifter) to the center of the 3 pole switch. Then either circuit will get power when the 3 pole is activated.. That any better.
