Sound deadening question
I wasnt sure where to post this, but considering alot of people use dynamat to insulate their systems, Id put it here....
I want to run a layer or 2 of dynamat throughout the vehicle. My goal is to deaden the sound of the tru-dual exhaust. Now I know this isnt a stereo question...But for those who have put this in their cars, did it noticeably cut down on exhaust note and resonance inside the car?
Thanks
Thanks
YES! I laid roll out mat then I used spray on deadening especially in the trunk area and almost all road noise is gone. Alot of resonance comes in from under the rear seats and wheel wells so I sprayed a good amount inside the inner walls behind the back seat speakers.
Dynamat is an expensive way to go, there are plenty of less expensive/equally as good alternatives.
It does make a noticeable difference. I would also consider using some form of closed cell foam to actually block out noise. The mats only reduce noise from vibration.
Check out what I did. Hope this helps.
