Heated seats installed. Big Problem
I had heated seats installed in my car the other day. The person who installed them, said that they were working fine for about 3 minutes and then he turned them off, and was going to move the car out of the shop. He went to start it, and there is no power. The things that don't work are: radio, cigarette lighter, xm radio(wired to cigarette lighter), whole gauge cluster. The car won't start. I remember that when I was taking out the gauge cluster, I blew a fuse that caused those things not to work. Do you guys think that this would be the problem? If not, what else can he check? Any help would be appreciated.
Thanks
Thanks
It sounds like he drew the power from the factory acc power. He needs to run a new wire from the battery to a relay powering the heaters, and let the relay get turned on by the factory acc power. More than likely just blew the fuse, so replace it, and don't turn the heaters back on till they are wired better.
Copy & Paste Moderator
-or-
B.) Did he replace a 10amp fuse with a 25amp fuse?
-or-
C.) Did he add this heater to an existing 25amp circuit and now possible push that circuit beyond its rating?
I hope he didn't do (B) or (C).
(especially not B)
