Amplifier power cable installation
Im not sure if there was a thread about this or not, But i was going to take my system and put it in my 98Z. The only problem i have had is where the power cable from the battery is the best route to go when running it to the back of the car. I took a glance at it and couldnt find the hole in the firewall, so left me to assume that i might have to drill out a hole.... but i dont want to have to do that, lol. Im just wondering which would be the best cleanest route i could take, and if there is a spot to already run the power wire through the firewall in my car because i could not seem to find it. Any suggestions? Thanks in advance.
LS1TECH & Trucks Sponsor
There is a hole behind the PCM. You can get to it from the inside without pulling the pcm out. I always just push wires and nitrous feed lines through from the inside far enough and they poke up over the pcm
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Took mine through same hole as described above. Similar manner to the shbox.com tutorial using a piece of home electrical Romex wire. Routed behind pass side kickpanel, all the way down next to pass seat under the panel to the rear. I did utilize some wire loom as well just for some added protection. Good luck.
