2000 SS, Weird Cluster Problem after jumpstarting...
Guys, Im a little new around here but tonight I was having some weird issues with my cluster. Two days ago the battery was dead, when I tried starting it the speedo and tach would bouce about half way up when the key was inserted and then go back to flat, didn't think anything of it. I jumped the car off tonight and let it idle for about 15 minutes before taking it around the block a few times. While on my drive I noticed several weird problems:
1. When headlights on, engine on, in gear (clutch out), cluster flatlines.
2. When headlights on and engine is on, in gear (clutch in), cluster works.
3. When headlights off, engine on, in gear (clutch out), cluster works.
4. Engine off, Acc on, cluster works.
I did a short search and saw people were having problems with clusters on 99's but didn't see anything quite like the problem I am having. Can anyone help??
Thanks!
Thanks!
Well I replaced the battery but that still didn't fix it. I noticed that on the way home pushing in the clutch really didn't have anything to do with the problem. It was the pressure of my left foot against the floorboard or the firewall. Somewhere under the carpet or behind the trim paneling I must have a loose wire. Anyone have any thoughts on where I should start checking for the loose connection?
I had similar problems in my T/A and as strange and unpredictable as the problems were it turned out to be a bad fuse.
