Wiring rader detector
I for one, took the next step and wired my own mute button and indicator LEDs:
http://ledvault.armorysound.com/Bria...ches%20015.mpg
You could always go this route
That LED set up is pretty cool. But I don't think I could pull off something that complex. Its going to be under the rear view mirror so i think I'm going to see about just wiring it into the mirror. That is, as soon as I get my new alternator in.
All you need to do is just get a 12 volt source that shuts off when you take the keys out and a ground. It's very easy, just look around the fuse panel and the wires under the steering wheel. It takes longer to hide all the wires and to make it look good then wiring it.
