Door Locks
Old 09-24-2008, 09:37 PM
cre81r's Avatar
Default Door Locks
My power door locks stopped working today,ugh,all i hear is a click from the passanger side door,changed relays and it still does the same thing.Where else should I look?
Old 09-24-2008, 10:57 PM
*98TransAm*'s Avatar
is this on both the driver and passenger side? or just the driver?
Old 09-24-2008, 11:05 PM
cre81r's Avatar
on both
Old 09-25-2008, 07:20 AM
Ungrounded Moderator
WhiteBird00's Avatar
I'm curious about what relays you changed since there are no relays in the power lock system.
Did you try using the switch on the passenger door? That would show if the driver's side switch was the problem. What about using the remote?
Old 09-25-2008, 09:01 AM
cre81r's Avatar
Well the fuses on the drivers side,none of them work,not even with the remote,the alarm just gets armed but doesnt lock.
Old 06-02-2009, 05:23 PM
Lt14mla's Avatar
im having the same problem. does anyone have any advice? the courtesy fuse looks fine...
