Two runs at the track
The camaro ran 13.7 at 108(found the time slip funny u guessed correct except about the tranny) it was a stick not sure if it was modded.Dont think so.Also Rob you got some sticky tires unlike me!For just a bolt on car ls1rob00's car(good driver too) does good,not bad on the highway either!Thanks for chiming in!Ran in the gear jammers class so I'm sure the camaro was a manual.
Op..I think you did pretty good considering what others were running. I also understand not wanting to break the rear end either and having to get it towed home. However, next time, I would try to get on it a little harder, man. Your car definitely has the potential to run good ETs based on your setup. I noticed LS1rob00 is a bolt-on car as he is running 12.5's. Keep practicing though because it is not as easy as some make it out to be. Good luck, man!
Nov 16 2011,wednesday night drags.Pretty sure it was the last wednesday they were open for the year.Friend told me two day's ahead and I was like **** it lets go!Took a little long to post the vid though,lol!
