Street Racing & Kill Stories Basic Technical Questions & Advice
Finally a spray pass
Old 03-03-2014, 02:40 PM
FourG63 97GST's Avatar
Default Finally a spray pass
Finally sprayed it the track. and got some data. didn't expect the results, but no complaints. did 10.98 and a few 11.0s, all at 138, 7.30s@103 in the 1/8.
going to work on making 1st gear a bit more useful. but 6spd,N20 on 18s, i'm not expecting much. Some street footage also with the Paxton 5.0. he was doing 10.70s that night i believe @137
Not the best footage, just threw this together.
Old 03-03-2014, 02:49 PM
flattusmaximus78's Avatar
Makes sense why your hauls *** on the highway man.
evangto87's Avatar
Nice runs. How much spray? And 103 in the 8th and 138 in the quarter??? You sure you didnt trap higher in the 8th? 35mph in the back half is retarded!
Old 03-03-2014, 03:39 PM
Ju1ce's Avatar
Good runs but unfortunately the traps going from 103 to 135 raise huge red flags.
There's just no way.
Old 03-03-2014, 03:45 PM
Gt4urass's Avatar
...and you know this because your Buick has run similarly?
Old 03-03-2014, 03:49 PM
FinalCam's Avatar
Interested in how there is no way
Old 03-03-2014, 03:56 PM
***Repost Police***
Irunelevens's Avatar
Are you spraying out of the hole, OP?
Old 03-03-2014, 04:05 PM
sw07gt's Avatar
Agreed, needs more details, 60ft, mod list, using a nitrous controller? Anyways if the trap is correct that's good for a mid to low 10 second pass on a good 60 ft.
Old 03-03-2014, 04:12 PM
Yes, i'm spraying out the hole, not using the progressive controller, It's a roll car, It works without it on the street. I didn't really prepare to go to the track.
I got some good logs, logs looks clean. I can work the AFR a little more, i'll leave timing alone, I'll be going for 140 next time out.
Don't really have to believe. I'm just a guy on the internet
tower made, a typo on one slip, can use the other two if you want, it was pretty consistent, so I didn't make any more passes.
Old 03-03-2014, 04:17 PM
automach1's Avatar
Motor pass?
Old 03-03-2014, 04:59 PM
sw07gt's Avatar
Definitely a lot left on the table in the first 330ft. What kind of tires?
Old 03-03-2014, 05:10 PM
Ju1ce's Avatar
Just looks way outta whack... if you've got 3.42s in the back a simple gearing calculator shows you crossed the line 128-130.
Old 03-03-2014, 05:11 PM
Car just isn't full tilt till after the 60'. I like it.
Old 03-03-2014, 05:22 PM
Heater's Avatar
That back mph is crazy.
Old 03-03-2014, 05:23 PM
Puck's Avatar
How are you calculating mph from gearing without knowing his tire size or RPM he is spinning to?
I'm running Toyo TQ radials, they where at 27psi. like I said, I didn't really plan this out, i got there late. and it was my first spray pass to get some data, i'll adjust from here
k, i'll take my fake vid and timeslips somewhere else, pls forgive me
I'm good with it too, once I get out of first, it's smooth sailing.
Old 03-03-2014, 05:25 PM
Ju1ce's Avatar
You don't have to get all butthurt about it I was just saying that the trap looked out of place. I also congratulated you on the good pass. 10s is moving and the ET's look spot on.
Old 03-03-2014, 06:14 PM
ASSuming On The Tree
audacious nick's Avatar
Yeah internet racers! You tell him how his stuff looks wrong because you googled it!
Old 03-03-2014, 10:18 PM
HioSSilver's Avatar
Nice passes! leaving soft and it still ran good.
Mod list?
Old 03-03-2014, 11:01 PM
willizm's Avatar
On my soft leave pass I hit 106mph in the 1/8th and 138mph in the 1/4. Doesn't seem to out of whack
Quick Reply: Finally a spray pass
