dan03mach how do you get LOW 11's/high 10's from a stock engined Mach 1??
Originally Posted by dan03mach
O Yeah BTW my car now runs low 11's, high 10's are coming next. And I still have a bone stock motor...
I know the Mach's are pretty darn fast stock and have plenty of potential, and are a real threat on the street (although they are few and far between in the UK, lol).
But can you really get them to run near a 10 second ET with just weight saving and suspension mods??? (Your sig doesn't say any of the mods you've done). You say it's a "bone stock motor" so presumable you still have stock intake and exhaust as these are essentially part of the engine (well at least as much as a water pump or valve covers are).
Also have you got any pics, I love the look of the Mach 1.
N.B. I know this isn't perhaphs strickly street racing, but it is relative as it's always good to know what can be acheived with other cars.
My Mach runs 11.8's on the stock long-block with just bolt-ons/suspension/weight reduction/gears/slicks n skinnies.
I fully expect to run 11.60's in the Spring with a good clutch/pressure plate/aluminum flywheel and no power-adder.
I still have the stock clutch/pressure plate/flywheel in the transmission in addition to the stock long-block components - stock heads, stock cams, stock compression, stock displacement.
All my accessories (power-steering/ABS/power brakes/heater/etc) are still in place too.
I do have a short-belt that by-passes the A/C but everything is still present/functional & I can have functioning A/C in 5-minutes by removing 1 bolt/swapping the tensioner & serpentine belts.
Better still, Jeff Schmell recently ran an 11.37 @ 118.12 mph in his '03 Mach 1 on drag radials - NO slicks with only minor internal mods such as a good valve job, different (but still Ford stock) cams, weight reduction and incredible driving.
No big cams, ported heads, stroked motor or tons of extra displacement.
(He of course has as many bolt-ons mods as his racing class allows - which isn't too many.)
His Mach runs in the NMRA "Factory Stock" class, so he has to weigh 3400 lbs & run TONS of stock parts (heavy stock K-member/stock un-ported intake/non-ported factory heads/mid-length headers/etc).
IMHO, his Mach is easily high-10-second capable if he didn't have to abide by those rules and could add long-tube headers/tubular K-member/ported intake manifold/etc.
Not taking anything away from Dan's ET - but I believe that his low 11's are on the bottle (Nitrous) not naturally-aspirated...
9 Sec. Club!!!
Originally Posted by 300bhp/ton
As the other thread was closed I thought I'd start another one. Just curious as to what you've done to your Mach 1 to get those times from it?
