NEW! Replacement Poly Ends for Rod Ends
Old 10-14-2008, 01:00 PM
UMI Performance's Avatar
Default NEW! Replacement Poly Ends for Rod Ends
Hello Members,
UMI Performance has developed and manufactured adjustable ends to convert rod ends to polyurethane bushings. These items are designed to replace 3/4-16 threaded rod ends used on panhard bars and control arms for the 1982-2002 F-Body. They work excellent to replace worn out rod ends or inexpensive rod ends making unbearable noise. They are priced at $29.99 each and available in red or black. Below is a link for additional information, if you have any questions please ask.
Thank you!
Ryan
http://www.umiperformance.com/produc...ategory_id=170
Old 10-15-2008, 01:27 AM
SS DNA's Avatar
Amazing!!! THANKS UMI, I have a Single Rod Ended PHB that I was wishing had two Poly Ends..... and be adjustable... But I didnt want to go sell mine and buy another one.
Old 10-15-2008, 02:15 AM
CranMaro99's Avatar
Exact issue here! I'm buying this.
Old 10-15-2008, 04:29 AM
Foxxtron's Avatar
Thank you so much Ryan!
This product is long overdue. Not only does this product make it easier for those to adjust their LCA's and PHB "double adjustable" style, but also retain the NVH insulating qualities that at least one poly or rubber bushing can offer.
Old 10-15-2008, 08:41 AM
Thanks guys! We have been wanting to bring these out for sometime now but just didn't get to it. We will be offer left hand threads as well very shortly.
We also have another cool bushing in the works as well... to be released soon
Thanks again!
Ryan
Old 10-17-2008, 06:42 PM
bad6as's Avatar
very vice, i never did think my rod ends were loud. what could the new bushing go on?
Old 10-17-2008, 09:27 PM
JonCR96Z's Avatar
more details?
Old 11-27-2008, 09:16 PM
sneaky7980's Avatar
Anyone try these out yet? If so with what brand PHR?
I plan on buying a pair for my pavlock PHR when they offer a left handed thread also.
Old 11-28-2008, 12:51 AM
JonCR96Z's Avatar
I got some to replace my UMI double adjustable rod ended LCAs. I changed the body mount side to try and quiet down some of the racket that the rod ended ones made. It definitely made a difference though its still not as quiet as my old LCAs with poly bushing on both ends.
Old 11-28-2008, 08:15 PM
Major_Lee_Slow's Avatar
I'd like a set to use with the UMI adjustable upper front control arm. Note the metal/non-metal ratio has to be the same or less.
Old 11-30-2008, 09:35 PM
cookba's Avatar
i can just buy 2 of these to make my rear rod/rod LCA into a rod/poly setup right? it doesnt matter about the thread right?
Old 12-01-2008, 04:38 PM
ss1
ss1's Avatar
cookba, you could use two of these to convert your rod/rod lca's into a poly/rod setup.
These are a great option for someone like myself who purchased a set of poly/rod lca's.
Nice work again UMI!
Quick Reply: NEW! Replacement Poly Ends for Rod Ends
