brake line fittings
Old 10-16-2008, 01:01 PM
1bdBULLITT's Avatar
Default brake line fittings
Doing a line lock install does any one know what size the fittings are that screw into the master and the ABS box???
Old 10-16-2008, 01:16 PM
01RedZ28's Avatar
What kit did you buy? They should come with it.
I'm not sure the exact size but go to Napa they will have them. There cheap so you'd be able to match them up.
Old 10-16-2008, 07:03 PM
SJM Manufacturing Inc's Avatar
We can supply any replacement fittings or lines you may need. Unless Napa has come out with new components, you probably won't find the OEM replacement pieces.
We do offer complete bolt-in kits which is a simple install (if you're considering making up a custom setup of your own.)
Old 10-17-2008, 08:36 PM
1bdBULLITT's Avatar
Awsome thanks I will let you know something soon.
Quick Reply: brake line fittings
