Rear Suspension too Stiff
Old 11-02-2008, 09:14 PM
marine02ss's Avatar
Default Rear Suspension too Stiff
I installed Hotchkis rear springs with QA1 shocks I already had. I adjusted the shocks to 2 from soft. The car felt real stiff, so I removed the bumpstop aluminum spacer which was bottoming out on the rear end. Now I have about 2 inches of travel from bumpstop to rear end but the car still feels a little stiff. What gives, I want to install some bilsteins shocks that I have to see it helps. I want that new car feel but with a lowered stance.I know its not going to be soft because the springs are a higher rate, but at least so it can be comfortable and nice.
Old 11-02-2008, 09:30 PM
Vndcatr's Avatar
Koni's ...Do it ... Hotchkis are great springs, you just need the correct Shock setup.. QA1's tend to be a little stiff..
Old 11-02-2008, 09:31 PM
JD_AMG's Avatar
Dragshocks + lowering springs = worst ride
If you want the car to ride well you need shocks that actually dampen the springs.
https://ls1tech.com/forums/showpost....5&postcount=26
Old 11-03-2008, 12:03 AM
marine02ss's Avatar
How would it feel with Hotchkis springs and bilsteins. Will it still be too stiff? Are Hotchkis springs and bilsteins a good combo?
Old 11-03-2008, 01:55 AM
99Bluz28's Avatar
Lightbulb
Try full soft on the QA1s in the rear for street driving.
You'll never get QA1s perfectly dialed in for street driving even the QA1 DAs ( I know since I've tried).
That's because their designed primarily for drag racing with street ability being a secondary concern.
Old 11-03-2008, 03:23 AM
ZMONSTER!'s Avatar
Maybe try the comp engeneering shocks? they seem to be a compromise between the koni's and QA1.
