Advice needed
Advice needed
Ok, heres some background. I have a 1995 Trans Am with 13600 miles it has a ram air hood and air box. I plan on lowering it with strano springs and using KYB shocks. I have a set of black TTMs for it too. I want to do alot of suspension work to it like LCAs TA Panhard rod etc. I know I will need lca relocation brackets but is there anything else i will need> What is the best stuff to use? This is in no way a race car its a cruiser.
I've gone all BMR with the exception of my shocks, which are Strano. If you don't have an STB or SFCs, I highly recommend both of those as well. As far as the Panhard bar, I'd go adjustable in case you have to correct the rear end suspension geometry after you lower the car.
What are you looking to improve by doing these mods?(you will want different parts for different wants, and some may go against what you want)
its highly recommended that you get an adjustable panhard bar when you lower the car because the distance from you car to the rear end will change from the shocks. meaning the stock phb will be too long and set the rear end off balance and it wont be centered under the car.
