How do i undo the hard brake lines that are on my axle?
LS1TECH Sponsor
Bend the tabs up and slide the lines out... In fact when you get the lines up it's easiest to just snap the tabs off so the clamp fits best. The brake line will end up running over the clamp and not able to be put in the tab anyway. And no aftermarket rear axle has the tabs, and the GM ones often rust and break off anyway....
__________________
