95-99 Neon spring sleeve instead of heater hose
Just thought I'd post up something I did instead of the "heater hose" mod on my last Z28. It's a spring sleeve for the front springs on a 95-99 Neon that they came out with for a rattling noise. It has a glue type sticky substance in them that holds them on the spring quite well. They retail for $2.65 for the pair, part number 05273399. They're no where near as thick as some heater hose for those looking for maximum drop in the rear.
I don't know where I could find a pic, but it's a thinner sleeve that is slit open on the inside middle so it can slide onto the spring easily. If you call a Chrysler/Dodge dealer and give them the part number, they may have it in stock so you could see it.
