Just ordered Spohn K-member kit got a ? on alignment
I ordered from www.BYUNSPEED.com the Spohn tubular K-member and upper and lower A-arms with the spiral rod ends, My question is how do you line the front end with rod ends ? are they preset ( threaded in the a-arm) i know the K-member is slotted for adjustment, but the A-arms them self how do you adjust the rod ends , Do i set them to stock length by measuring the stock A-arms.
Set them to factory length and let the alignment shop use the slots in the K-member to set the alignment. If you are looking for particular caster or camber then they may need to remove the A-Arms to get the correct #'s. But otherwise you should be fine.
Hope that helps!
Ryan
Hope that helps!
Ryan
