tq arm problem
tq arm problem
i have a stock tq arm and rear with mods in sig and my cars tuned well when i have the car in first gear and am rolling to a stop sign or whatever , the car bucks a little i know thats normal because of the cam. but instead of the car bucking it does also but i hear like a clunk by my tranny. i went under there the other day and the tq arm was actally loose by the rear i tighted up the bolts and it helped alot but didint solve the problem. is this a common problem or what? i also just replaced my trans mount when i tightend the tq arm
I would recommend double checking the rear of the stock torque arm to make sure it's not cracked (common on 6-speed cars). If the torque arm is cracked at the rear it would explain the loose bolts on the rearend housing.
If it is cracked we do offer a variety of different replacement torque arms for every application. A link to our torque arms can be found here-
Let me know what you find out after the reinspecting the vehicle.
