Can you use your stock shocks
you can but the ride quality will suffer. you might as well put new shocks on while your tackling the lowering springs since it all goes together and so you won't have to worry about it later on.
Don't have to but you should change the shocks. If you have an extra car or someone to take you to the shop I'd take the front shock assemblies off before you take them to the shop to save you some money. I just used spring compressors myself but if you don't want to risk it that's understandable. If you do decide to use spring compressors I suggest you buy a decent set. I don't trust rented spring compressors or Harbor Freight specials here.
I own a shop..I have mechanics that can do it for me..I don't have a spring compressor,but I know some shops that do and they can do it for me..I don't want to spend big bucks on shocks tho..
That's the thing..I know its convenient to put new shocks in at the same time,but I don't really want to spend the $ on it if I don't have to.My shocks are perfectly fine..But if that is a prerequisite then I would be forced to do it. Also,how much stiffer is the ride with lowering springs?
You dont want to spend any $$ on shocks but in the long run you'll be better off to do it all at once. Saves you from doing everything twice including the alignment.
BTW you get what you pay for in regards for shocks, and this is not a place where you want to skimp believe me.
Save your money for quality shocks and do it all at once.
Ok,well I was thinking about doing a drop and getting new wheels and tires or getting a stall,heard they were fun..But both have other things you need to do in addition,that's the problem..
I hear ya man but better to keep it simple and pay attention to one area at a time.
That way when it's done it's done and you don't have to worry about it.
My car had 120+K miles on the suspension and was in need of help. I did my research and did Strano/Koni's plus added Sam's Swaybars aswell and now it's a whole different car. Now I'n moving up to clutch and brakes.
The "stiffness" of the ride will depend on which spring you pick, and of course the shocks you have (among other things). It will depend on your personal preference.
What do you do with your car? That will effect what you should get. What kind of ride quality and suspension control do you consider tolerable? That isn't anything we can help you with unfortunately. You will have to either find someone with a similar setup to what you want and test it out, or just give it a go.
Basically stock shocks won't properly dampen any springs, arguably not even stock springs. The best shock to dampen most of the fbody aftermarket springs are Koni's as most people can tell given they do a search. KYB appears to be a distant cheaper 2nd choice for good dampening, but the fact that one **** controls both compression and rebound leaves you looking for a happy medium. KYB has poor warranty (don't let KYB know you are on aftermarket springs if you bust them). Bilstiens aren't really valved for aftermarket springs, but are built well.
It seems like a lot of people also tend to just cut the stock shock shafts to get them removed due to the shock shaft nut being stuck in most cases. Something to keep in mind in case you find yours stuck too.
So anyways, you CAN use stock shocks on other springs, but its a risk you take with paying less money. If you like the combination, then you made the right choice. If not, then you'll probably end up spending extra time and money to fix the first attempt.
