Rear coil spring spacer?
i searched but had no luck in the first 5 pages, so i gave up. for some reason the rear sits a bit lower than the front on my t/a, and i could use a spacer for the springs. it is the same with the stocks or a new set of lowering springs so it isnt the springs, i think. i still have the isolators in the rear, so i would think it needs to be on the bottom. does anyone know of a 1/2 to 3/4 " spacer available? right now i am running 1.5 inch springs in the front and stocks with the hose mod in the rear, and id like it to be lower. thanks!
I'm running the Eibach Pro-Kit and my heavy stereo caused my rear to sag a little bit. I bought rubber spacers from my local Pep-Boys for like $10 each and they brought the rear up about a 1/2". This is what they look like:
http://store.summitracing.com/partde...5&autoview=sku
They just install between one of the coils on the springs and keep it from compressing all the way.
