Rear Wheel Hop
Rear Wheel Hop
Guys I recently did some weight reduction and part of it was taking out the rear bumper support.
Today I noticed the rear hopped a little when I got on it.
Suspension wise I have an adj rod end phb, konis (set to medium) and a 21mm sway bar.
What could be causing the rear to hop under hard acceleration and can I do anything to fix it?
Thanks for reading.
Thanks for reading.
i personally would not use relo's unless your lowered. Maybe after you install the LCA's and decide if they helped enough to go on without them. If you install the LCA's and decide to go ahead with the relo's then go for it. better to spend the money later as you might not need to spend it at all,,, its only one bolt per side you'd have to remove. But yes, you need better LCA's
LS1Tech Premium Sponsor
Thanks for reading.
Thanks for reading.
