what manual rack can i get to bolt right up
Check out BMR, they have their own configuration. I'm not sure if their setup needs a bracket welded or not. It's slightly different than Madman's configuration.
Madmans rack has a bracket that needs welded. Madman carries both BMR's and their own obviously. Give them a call, they can help you sort your questions out quickest.
Good luck!
Good luck!
LS1Tech Premium Sponsor
Thanks Steve!
If you have the AJE K member with the stock rack mounts, our RK002 will let you bolt on the pinto rack.
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Glenn ***
Sales Tech
813.986.9302
